Onderwerp: THE WORLD'S FASTEST S13
THE WORLD'S FASTEST S13 17 aug 2009 12:56 #2705
Buick 8 cilinder in lijn motor!
Re:THE WORLD'S FASTEST S13 17 aug 2009 13:49 #2706
What the hell is dat voor motor?!?!?!?!
Re:THE WORLD'S FASTEST S13 17 aug 2009 14:03 #2708
dat staat er toch ;)
"Buick 8 cilinder in lijn motor!"
:P
Re:THE WORLD'S FASTEST S13 17 aug 2009 14:05 #2709
Duhh..... specs!
Re:THE WORLD'S FASTEST S13 17 aug 2009 14:31 #2710
Das een motor die je niet vaak ziet, zo'n 8 in lijn!
Heb je ook een filmpje van de run?
Re:THE WORLD'S FASTEST S13 17 aug 2009 15:34 #2711
Ge-wel-dig! Haha, een sidepipe in het voorspatbord! :laugh:
Re:THE WORLD'S FASTEST S13 17 aug 2009 15:34 #2712
Op mijn werk doet youtube het niet!
Re:THE WORLD'S FASTEST S13 17 aug 2009 16:07 #2715
En...?? Maar hier wel :P .
Heb je wel de link?
Re:THE WORLD'S FASTEST S13 17 aug 2009 16:12 #2716
Heb nog wat info gevonden op: TurboMagazine
1994 Nissan 240SX - McMeekin Bros
"Engine Swap?...We're Doin' It Backwards Here; New Car, Antique Engine."
I saw this 240SX from quite a distance and recognized it as Nissan iron immediately. Needless to say I kicked up a salty rooster tail getting over to the car to check it out and talk with the owners. Expecting an SR20DET or the mighty RB26DETT Skyline bullet I was dumbfounded; the putrid rankness of salt attacking my tastebuds as my jaw dragged in the Bonneville slush as I gazed at a flathead V8? Dave McMeekin said, "we're doin' it backwards here; new car, antique engine."
The best thing about Bonneville is the diversity of cars and car/engine combinations. If you're a purist (import or otherwise) you need to check you preconceived notions at the asphalt because it's not 'what' it is; it's how 'fast' it is that counts around here.
I talked to Jane McMeekin about the car and my facts are a little sketchy as the shock of that flathead was hard to shake. As I have it, Don drives the car in the XF/G-ALT category. Jane got her license in the car in XF/GC configuration and posted a two-way average of 149.97 mph, a new record. I remember the car being in impound, which meant it was one run away from a record so this seems to make sense. Life is indeed a box of chocolates, you never know what you're gonna get (when you pop the hood).
MCMEEKIN BROS. 240SX [#280]
Owner: Don McMeekin
Car: 1994 Nissan 240SX
Driver: Don McMeekin, Jane McMeekin
Crew Chief: Dave McMeekin
Engine: 296 CID Flathead V8
Make: Ford
Fuel: Hilborn Mechanical Fuel Injection
Class: XF/GC, XF/G-ALT
Record: 130.058 mph [XF/GC]
Top Speed: 149.97 mph [new record XF/GC]
Laast bewerkt: 17 aug 2009 16:15 Door Ray.
Re:THE WORLD'S FASTEST S13 17 aug 2009 19:44 #2722
ik hou van lijn motoren met 2 kleppen boven de zuiger.
toen ik die motor zag dacht ik eerst aan een duesenberg straight 8
dit lijkt een 4 in lijn maar is het niet
zijn er nog meer fabrikanten met 8 in lijn?
Laast bewerkt: 17 aug 2009 19:51 Door Maurice.
Re:THE WORLD'S FASTEST S13 17 aug 2009 19:55 #2723
gevonden
pontiac staight 8
http://farm1.static.flickr.com/152/359608148_c423c0b85a.jpg?v=0
Re:THE WORLD'S FASTEST S13 17 aug 2009 20:11 #2724
gevonden
pontiac staight 8
Dat ziet er goed massief uit :) ...
Re:THE WORLD'S FASTEST S13 17 aug 2009 20:36 #2727
Daar was ik ook al naar aant zoeken. Er moet ook een Jag racer zijn uit de 50'er jaren met een 8 in lijn
Re:THE WORLD'S FASTEST S13 18 aug 2009 12:32 #2732
moet toch te vinden zijn?
Re:THE WORLD'S FASTEST S13 18 aug 2009 12:36 #2734
Bedoelen jullie deze Jaguar?
De V8 in lijn zou ik niet weten, deze had een V12.
Laast bewerkt: 18 aug 2009 12:42 Door Ray.
Re:THE WORLD'S FASTEST S13 18 aug 2009 15:56 #2740
Ray schrijft:
De 8 in lijn zou ik niet weten, deze had een V12.
heb je een tekening van een v8 in lijn??? :ohmy: :P
Laast bewerkt: 19 aug 2009 12:17 Door Ray.
Re:THE WORLD'S FASTEST S13 18 aug 2009 16:44 #2741
de tekening lijkt wel een v10???
Re:THE WORLD'S FASTEST S13 18 aug 2009 17:03 #2742
was als grapje bedoeld. volgens mij heb of een v8 of een 8 in lijn.
geen v8 in lijn :P
Re:THE WORLD'S FASTEST S13 18 aug 2009 22:38 #2751
Ik ben nog even verder aant zoeken; wel veel mooie plaatjes!
Motor van een D-type uit 1954:
De D-type zelf:
Toch iets gevonden;
Bugatti 700 ci in line 8
Re:THE WORLD'S FASTEST S13 19 aug 2009 09:59 #2754
Bugatti 700 ci in line 8 erg mooi.
dat is het 4e merk al dat 8 in lijn bouwt.
Time to create page: 0.301 seconds
